Memory usage
Tue Sep 1 16:02:53 UTC 2009
Aleix Conchillo Flaqué wrote:
> On Tue, Sep 1, 2009 at 14:20, Martin Grim<W.M.Grim at sron.nl> wrote:
>> Hi,
>> I'm a bit paranoid about memory usage on my system. Are there means within rtems to see amount of memory used or still free?
> Compile RTEMS with MALLOC_STATS defined and call malloc_dump() in your program.
Only in old versions.  Configured at application link time now.
CONFIGURE_MALLOC_STATISTICS
CONFIGURE_MALLOC_DIRTY
Also renamed and added a few new routines:
malloc_get_statistics() - info returned in structure
malloc_report_statistics()  - prints via printk
malloc_report_statistics_with_plugin() - prints using the printf
  style routine you provide
> Aleix
> rtems-users mailing list
> rtems-users at rtems.org
