How to add a compile time configuration option to something in cpukit?
Thu Sep 3 11:41:17 UTC 2009
Ralf Corsepius wrote:
>>> On 09/03/2009 12:18 PM, Sebastian Huber wrote:
>>>> Hi,
>>>> the FTP client resides in the cpukit.  It can use gethostbyname() to
>>>> obtain an
>>>> internet address from a DNS name.  The dependency on DNS adds 35k of
>>>> code
>>>> (THUMB op-codes).  I want to add a configuration option to disable this
>>>> feature.  Can I add this with RTEMS_CPUOPT in cpukit/configure.ac?
>>> As I repeatedly wrote, before: All -m* flags must be global (i.e. *.cfg)
>>> What you are trying to do violates the working principles of multilibs,
>>> so no way.
>> Sorry now I am a little confused.  What is the connection to multilibs
>> if I can
>> enable or disable DNS support in the FTP client?
> Here:
> "cpukit/configure.ac"
So it is officially impossible to customize the cpukit via configure options?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
