How to add a compile time configuration option to something in cpukit?
Thu Sep 3 12:22:31 UTC 2009
Sebastian Huber wrote:
> Ralf Corsepius wrote:
>> On 09/03/2009 12:18 PM, Sebastian Huber wrote:
>>> Hi,
>>> the FTP client resides in the cpukit.  It can use gethostbyname() to
>>> obtain an
>>> internet address from a DNS name.  The dependency on DNS adds 35k of code
>>> (THUMB op-codes).  I want to add a configuration option to disable this
>>> feature.  Can I add this with RTEMS_CPUOPT in cpukit/configure.ac?
>> As I repeatedly wrote, before: All -m* flags must be global (i.e. *.cfg)
>> What you are trying to do violates the working principles of multilibs,
>> so no way.
> Sorry now I am a little confused.  What is the connection to multilibs if I can
> enable or disable DNS support in the FTP client?
Everything under cpukit is intended to be compiled one
way using only multilib options and all configuration
is to be done via application link time configuration
options.
Yes.. I know there are a few compile time options.  If
you  know how to turn those into link time options,
they can disappear also.
The ftpd DNS option is straightforward to implement as a
application link time plugin.
