Problems with printing double-values with printf and sprintf
Fri Sep 4 14:50:23 UTC 2009
The calculation in dtoa.c line 295 is wrong because the values for Exp_shift1
and Exp_mask are invalid for the little endian ARM (this is only a good guess
at the moment).  Exp_shift1 has the value 20 and should have the value 23.
These values are defined in
./newlib/libc/stdio/vfieeefp.h
./newlib/libc/stdlib/mprec.h
It looks like the __IEEE_LITTLE_ENDIAN is undefined.
Sebastian Huber wrote:
> The problem is in the function dtoa_r() in file dtoa.c line 430. Somehow the
> value for _REENT_MP_RESULT(ptr) is to big and arbitrary memory will be overwritten.
> Ralf Corsepius wrote:
>> On 08/17/2009 12:34 PM, Christian Mauderer wrote:
>>> I'm using the newlib 1.17.0 with RTEMS 4.10 patches out of the
>>> rtems-4.10-newlib-common-1.17.0-44.suse10.3 rpm.
>>> I'm using the following CFLAGS:
>>> -mcpu=arm7tdmi-s -mstructure-size-boundary=8 -mapcs-frame -mthumb -Os -g
>> Well, that's a lot of obscure flags, of which each may cause your problem.
>> => We need to further isolate the problem.
>> Can you try to build and excute something similar to this:
>> printf( "%f\n", 1.2345 );
>> while permuting the CFLAGS you are using, esp.
>> -mcpu=arm7tdmi-s, -mapcs-frame and -mthumb?
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
