errors in cpukit/libcsupport/src/base_fs
Fri Sep 4 22:51:07 UTC 2009
e.stiebler wrote:
> Joel Sherrill wrote:
>> e.stiebler wrote:
>>> Hi All,
>>> trying to compile RTEMS CVS, after a fresh checkout and tool chain
>>> update. Getting the same problem on m68k & powerpc. (using fedora 11)
>> Are those funny characters really in you copy of the libio.h file?
> No, just noticed that. That's from copying from gnome-to-vi-to-windows ;-)
>> This is using the native C compiler.  Not an RTEMS cross!
>> Are you sure you have the RTEMS tools at the front of your
>> PATH?
> Yes, it seems, that the rtems/configure script doesn't detect the
> configuration I have. It defaults to the :
> checking for RTEMS Version... 4.9.99.0
> checking build system type... i686-pc-linux-gnu
> checking host system type... i686-pc-linux-gnu
> checking target system type... i686-pc-linux-gnu
> checking rtems target cpu... unix
What was your actual RTEMS configure line?
> But the environment is set to :
> RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/m68k-rtems4.10/mvme162
> OLDPWD=/AD1/SHARED/RTEMS
> INSTALL_POINT=/opt/rtems-4.10
> PATH=/opt/rtems-4.10/bin:/usr/kerberos/sbin:/usr/lib/qt-3.3/bin:/usr/kerberos/bi
> n:/usr/lib/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/
> home/emu/bin
> TARGET_CONFIGURATION=m68k-rtems4.10
> PWD=/AD1/SHARED/RTEMS/build-mvme162
> And I think I'm using this same setup for quite a while already.
> (But installed a fresh FEDORA 11)
> So, were there any changes I missed ?
> Cheers & thanks
