Problems with floating-point support on ARM
    Sebastian Huber
    Thu Sep 10 11:29:35 UTC 2009
Ralf Corsepius wrote:
> On 09/10/2009 11:06 AM, Sebastian Huber wrote:
>> Hi,
>> RTEMS currently supports only soft-float ARM
> What makes you say so?
cat cpukit/score/cpu/arm/rtems/score/arm.h
>> The
>> default floating-point model for GCC on ARM is FPA.
> AFAICT, correct.
>> That means (excerpt from the corresponding ARM document):
>> Little-endian double-precision values are neither pure little-endian
>> nor pure
>> big-endian.
>> This differs from that more recent VFP (Vectored Floatin-Point
>> architecture).
>> In IEEE 754 we have the following double format:
>> least significant word (lsw): fraction [31:0]
>> moast significant word (msw): sign | exponent | fraction [51:32]
>> This will be stored in different ways:
>>                   VFP LE    VFP BE    FPA
>> lower address       lsw       msw    msw
>> higher address      msw       lsw    lsw
>> The important thing here is that on little-endian the msw and lsw are
>> switched.
>> Newlib does not support the FPA floating-point model on little-endian.
> What is missing according to your view?
It would require to much work to support FPA on little-endian in newlib.
>> In this
>> case it produces wrong results and writes to arbitrary memory locations.
>> A possible fix is to add the following options to the GCC
>> configuration command
>> line:
>>      --with-float=soft
>>      --with-fpu=vfp
>> The VFP floating-point hardware model is not implemented in GCC,
> What I see inside of the GCC source code speaks, doesn't match with your
> claim.
arm-rtems4.10-gcc -mfpu=vfp -mfloat-abi=hard test.c
test.c:1: sorry, unimplemented: -mfloat-abi=hard and VFP
>> thus the
>> hard-float multilibs have to be disabled in gcc/config/arm/t-rtems.
> Let me bring this hardly readable verbosity to the point: What do you
> want us to do?
> Do you want us to change the default fpu to vfp instead of fpa?
Yes.
> Comments from other arm users? Will vfp work for your boards?
> Ralf
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
