RTEMS 4.10 on Fedora 10 Virtual Machine: Problems compiling SPARC examples
Luis Mollinedo Herrera lmollinedo at gmv.com
Thu Sep 10 18:09:40 UTC 2009
Hello,
We are trying to start to work with the virtual machine described here:
    http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
But when we have tried to build all the SPARC examples with these instructions:
"cd $B
mkdir b-sis
cd b-sis
sh -x ../build-sis
make"
We get this error:
Making all in hello
gmake[5]: Entering directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c/sis/testsuites/samples/hello'
sparc-rtems4.10-gcc -B../../../../../sis/lib/ -specs bsp_specs -qrtems -DPACKAGE_NAME=\"rtems-c-src-tests-samples\" -DPACKAGE_TARNAME=\"rtems-c-src-tests-samples\" -DPACKAGE_VERSION=\"4.9.99.0\" -DPACKAGE_STRING=\"rtems-c-src-tests-samples\ 4.9.99.0\" -DPACKAGE_BUGREPORT=\"http://www.rtems.org/bugzilla\" -DPACKAGE_URL=\"\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -I. -I../../../../../../../rtems/c/src/../../testsuites/samples/hello     -mcpu=cypress -O2 -g -MT init.o -MD -MP -MF .deps/init.Tpo -c -o init.o ../../../../../../../rtems/c/src/../../testsuites/samples/hello/init.c
mv -f .deps/init.Tpo .deps/init.Po
sparc-rtems4.10-gcc -B../../../../../sis/lib/ -specs bsp_specs -qrtems -mcpu=cypress -O2 -g    -mcpu=cypress   -o hello.exe init.o ../../../../../sis/lib/no-barrier.rel ../../../../../sis/lib/no-dpmem.rel ../../../../../sis/lib/no-event.rel ../../../../../sis/lib/no-msg.rel ../../../../../sis/lib/no-mp.rel ../../../../../sis/lib/no-part.rel ../../../../../sis/lib/no-region.rel ../../../../../sis/lib/no-signal.rel ../../../../../sis/lib/no-timer.rel ../../../../../sis/lib/no-rtmon.rel ../../../../../sis/lib/no-ext.rel
/opt/rtems-4.10/lib/gcc/sparc-rtems4.10/4.4.1/../../../../sparc-rtems4.10/lib/libc.a(lib_a-makebuf.o): In function `__smakebuf_r':
/builddir/build/BUILD/rtems-4.10-sparc-rtems4.10-gcc-4.4.1/build/sparc-rtems4.10/newlib/libc/stdio/../../../../../gcc-4.4.1/newlib/libc/stdio/makebuf.c:110: undefined reference to `_isatty_r'
collect2: ld returned 1 exit status
gmake[5]: *** [hello.exe] Error 1
gmake[5]: Leaving directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c/sis/testsuites/samples/hello'
gmake[4]: *** [all-recursive] Error 1
gmake[4]: Leaving directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c/sis/testsuites/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c/sis/testsuites'
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c/sis'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/home/rtems/rtems-work/b-sis/sparc-rtems4.10/c'
make: *** [all-recursive] Error 1
[rtems at VirtualRTEMS b-sis]$
Any ideas?
Thanks in advance,
Luis Mollinedo
Project Engineer
Advanced Space systems and Technologies
GMV Aerospace and Defence S.A.
______________________
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
 puede contener informacion clasificada por su emisor como confidencial
 en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
 erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
This message including any attachments may contain confidential
information, according to our Information Security Management System,
 and intended solely for a specific individual to whom they are addressed.
 Any unauthorised copy, disclosure or distribution of this message
 is strictly forbidden. If you have received this transmission in error,
 please notify the sender immediately and delete it.
