qemu-uc58282 first test results
Joel Sherrill
joel.sherrill at OARcorp.com
Thu Sep 10 18:55:42 UTC 2009
Hi,
Thanks to Till's work, I was able to add qemu-uc5282
support to the sim-scripts and try to run all RTEMS
non-networked tests on the simulator. Almost all
tests passed. I would appreciate someone checking
the following tests on real hardware since they
fail on the simulator.
+ sp15 - failed with error
rtems_partition_create of PT1 FAILED -- expected (successful completion)
got (address specified is invalid)
+ spintrcritical15 - could not create semaphore
+ spintrcritical16 - could not create semaphore
+ spprintk - no output
This is robably failing because the debug IO
is not initialized when the console is disabled.
Feedback from someone with real hardware would
definitely be appreciated. I want to have faith in this
target before attempting to run all of the GCC C, C++
and Ada tests. :)
