qemu + uC5282 (was Re: Converting RTEMS ELF files into Linux bootimages)
Till Straumann strauman at slac.stanford.edu
Fri Sep 11 04:33:03 UTC 2009
Joel Sherrill wrote:
> Till Straumann wrote:
>> FWIW:
> Holy moley!! Great job!!!  Thank you!!!
> This will let us start to test the tools on
> Coldfire.  That was the most commonly
> used target architecture we had no
> way to test on a simulator.
> Will you please submit this to qemu?
> And make it apply against the couverture project's
> qemu source?
Sorry Joel - but this has not a high priority for me. I have
some 'real' work to do and already spent my available
'fun-time' hacking this together.
I could submit the patch to qemu -- should I just
post to their developer's mailing-list?
T.
> I am really looking forward to being able to test
> using this.
> I have added an initial version of the wrapper script
> to gcc-testing/sim-scripts.
>> I was able to hack qemu so that the uC5282 BSP can be run.
>> I tested 'hello.exe', 'ticker.exe' and my usual, pretty
>> complete 'GeSys.exe' application which includes the cexpsh
>> shell and full networking.
>> 1) patch qemu-0.11.0-rc1 to add some missing features,
>>    some dummy-registers and a bug-fix.
>>    The following hardware is (partly) emulated:
>>      - interrupt-controller
>>      - 3 UARTs
>>      - 4 PITs (timers)
>>      - reset controller (software-reset)
>>      - FEC ethernet (MIB counters not implemented)
>> 2) patch the uC5282 BSP (patch has already been added to RTEMS HEAD)
>> build qemu
>> mkdir build-m68k
>> cd    build-m68k
>> ../configure --target-list=m68k-softmmu
>> make
>> Run qemu using the RTEMS ELF binary:
>> m68k-softmmu/qemu-system-m68k -M uc5282 -nographic -kernel hello.exe
>> -- Till
