PowerPc Open PIC for EP1A
Jennifer Averett
Jennifer.Averett at OARcorp.com
Tue Sep 15 19:24:37 UTC 2009
I am debugging the EP1A in RTEMS 4.9 and am having a problem which I suspect is related to the open pic initialization.
The interrupt for the serial devices does not seem to be generated. I would appreciate someone who is familar with the
open pic initialization to take a look at the changes I made between the known working 4.6 version that I have and the
version I am debugging. I have attached the pertinent files for comparison. Specifically I would like to know if the
tables in irq_init.c look correct given the changes in irq.h. In 4.6 the shared irq.h was used and the irq value adjusted
by a custom irq.c in the bsp. In 4.9 I am using a custom irq.h and the new cpu irq code in
The three files in question for each tree are attached and named according to tree and file.
Any help would be appreciated,
Jennifer Averett
Type: text/x-chdr
Desc: rtems-4.9.irq.h
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment.bin>
Type: text/x-csrc
Desc: rtems-4.9.irq_init.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment-0001.bin>
Type: text/x-csrc
Desc: rtems-4.9.openpic_xxx_irq.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment-0002.bin>
Type: text/x-csrc
Desc: rtems-4.6.irq.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment-0003.bin>
Type: text/x-chdr
Desc: rtems-4.6.irq.h
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment-0004.bin>
Type: text/x-csrc
Desc: rtems-4.6.irq_init.c
URL: <http://lists.rtems.org/pipermail/users/attachments/20090915/33cf9b4a/attachment-0005.bin>
