PowerPC in_cksum() needs -O
Mon Sep 21 21:03:39 UTC 2009
Peter Dufault wrote:
> On Sep 21, 2009, at 2:12 , Peter Dufault wrote:
>> I've tracked it down to everything getting dropped with a bad
>> checksum in tcp_input() at line 321.
> I had built with optimization off for debugging.  Without optimization
> in_cksum() is returning 1.  With -O2 in effect it is returning 0.
> I put a breakpoint right after the call to in_cksum() with the only
> change recompiling tcp_input.c with and without optimization.
> Checksum with tcp_input.c compiled with -O2:
> (gdb) print ti->ti_t.th_sum
> $1 = 0x0
> (gdb)
> Checksum with tcp_input.c compiled without any optimization:
> $1 = 0x1
> (gdb)
> I'll open a bug.
It is probably some less than perfectly specific
asm constraint.  Can you check the current
BSD source for the implementation?  It may
already be fixed.
--joel
> Peter
> rtems-users mailing list
> rtems-users at rtems.org
