Installing RTEMS on my host machine
Sergio Faustino sergio.faustino at edisoft.pt
Mon Sep 28 16:37:27 UTC 2009
On Friday 25 September 2009 22:04:44 Pablo Salinas wrote:
> Hi there,
Hi!!
>                I use a debian desktop at campus:
> Linux version 2.6.26-2-amd64 (Debian 2.6.26-17lenny2) (dannf at debian.org)
> (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25))
> and I am trying to install RTEMS 4.9. I am completely new to RTEMS.
> I had tried both approaches: RPMs and Zipped Tar Files using the Getting
> Started with
RTEMS<http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.9.2/share/rtems/
>html/started/index.html>manual.
> So, apparently I need root access for any of both approaches to work,
> right? Is there any workaround to that?
Actually, you can skip "Chapter 3: Prebuilt Toolset Executables" and go
directly to "Chapter 4: Building the GNU Cross Compiler Toolset" and use the
direct invocation of configure and make commands. Of course, you will need
to configure and install of the tools. In my computer, this takes about
~30min to compile GCC (which is the longest).
For the set of instructions there (Chapter 4 and Chapter 5) you don't
require root access as long as you are installing and building in a
directory where you have write permissions.
PS: if you want, you can download a tool that configure and install RTEMS
(and other things) at http://rtemscentre.edisoft.pt.
Best regards
Sergio Faustino.
> Besides, it seems like depending on your target architecture gcc, binutils
> and newlib all get patched. Would that affect my old gcc compiler? Or will
> it remain independent from my gcc shell command?
> Thanks in advance.
> regards,
>             Pablo S.
