Using smc91111.c on powerpc and libchip/network questions
Sebastian Huber
Thu Sep 3 11:15:24 UTC 2009
Peter Dufault wrote:
> On Sep 3, 2009, at 3:09 , Sebastian Huber wrote:
>> This is already cleaned up (the mpc55xx was the first BSP that uses
>> this, it is
>> required here due to the nearly 400 interrupt sources):
> I found this yesterday. This is based on the work Til provides in
> c/src/lib/libcpu/powerpc/new-exceptions/bspsupport, correct? I was
> comparing the BSP Makefile.am file with what Til says to do in his
> README and I think your changes supersede his recommendations. Maybe an
> addition to his README to reference your work is in order.
> Peter
The exception and interrupt handling are two completely different things here.
On PowerPC the external exception (among other types) handler code resides in
c/src/lib/libcpu/powerpc/new-exceptions. Here are the prologues and epilogues
that deal with the different exception types. The interrupt support stuff in
c/src/lib/libbsp/shared deals with the specific interrupt sources that cause an
external exception.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
