errors in cpukit/libcsupport/src/base_fs
e.stiebler emu at e-bbes.com
Fri Sep 4 21:37:12 UTC 2009
Joel Sherrill wrote:
> e.stiebler wrote:
>> Hi All,
>> trying to compile RTEMS CVS, after a fresh checkout and tool chain
>> update. Getting the same problem on m68k & powerpc. (using fedora 11)
> Are those funny characters really in you copy of the libio.h file?
No, just noticed that. That's from copying from gnome-to-vi-to-windows ;-)
> This is using the native C compiler.  Not an RTEMS cross!
> Are you sure you have the RTEMS tools at the front of your
> PATH?
Yes, it seems, that the rtems/configure script doesn't detect the
configuration I have. It defaults to the :
checking for RTEMS Version... 4.9.99.0
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking rtems target cpu... unix
But the environment is set to :
RTEMS_MAKEFILE_PATH=/opt/rtems-4.10/m68k-rtems4.10/mvme162
OLDPWD=/AD1/SHARED/RTEMS
INSTALL_POINT=/opt/rtems-4.10
PATH=/opt/rtems-4.10/bin:/usr/kerberos/sbin:/usr/lib/qt-3.3/bin:/usr/kerberos/bi
n:/usr/lib/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin:/
home/emu/bin
TARGET_CONFIGURATION=m68k-rtems4.10
PWD=/AD1/SHARED/RTEMS/build-mvme162
And I think I'm using this same setup for quite a while already.
(But installed a fresh FEDORA 11)
So, were there any changes I missed ?
Cheers & thanks
