PowerPC in_cksum() needs -O (was: Re: Loopback test failing, not returning from rtems_bsdnet_event_receive())
Peter Dufault dufault at hda.com
Mon Sep 21 21:00:38 UTC 2009
On Sep 21, 2009, at 2:12 , Peter Dufault wrote:
> I've tracked it down to everything getting dropped with a bad
> checksum in tcp_input() at line 321.
I had built with optimization off for debugging.  Without optimization
in_cksum() is returning 1.  With -O2 in effect it is returning 0.
I put a breakpoint right after the call to in_cksum() with the only
change recompiling tcp_input.c with and without optimization.
Checksum with tcp_input.c compiled with -O2:
(gdb) print ti->ti_t.th_sum
$1 = 0x0
(gdb)
Checksum with tcp_input.c compiled without any optimization:
$1 = 0x1
(gdb)
I'll open a bug.
Peter
