error at startup running Hello World Example in rtems 4.6.6 / erc32 bsp
Andrei Chichak
groups at chichak.ca
Wed Sep 30 04:27:15 UTC 2009
Nicolas,
I found the problem in my BSP after a LOT of looking.
It turns out that my linkcmds file was not working properly and
start.S, in copying ROM to RAM, did not use the proper addresses,
corrupting the .data section.
This was causing calloc to fail setting up the work area.
I would suggest creating a variable in your program like:
int fu = 42;
and run through the initialization code and make sure that fu is being
initialized properly.
With your code, it looks like you are trying to initialize 4GB of RAM.
Either you have a lot of memory or the value of work_area_size got
smashed.
Hope this helps,
Andrei
On 2009-September-24, at 9:51 AM, Nicolas Horro wrote:
> Hello,
> when downgrading from rtems 4.8.0 to rtems 4.6.6 I found that the
> "hello world" example in real hardware with ERC32 bsp fails at
> startup when executing the function
> RTEMS_Malloc_Initialize( heap_start, heap_size, use_sbrk ).
> The line that fails is the memset() call.
> if (!starting_address) {
> if ( rtems_cpu_configuration_get_do_zero_of_workspace() )
> memset( starting_address, 0, length ); /* <= error */
> I believe this error is caused because <starting_address> and
> <length> have invalid values:
> (gdb) x starting_address
> 0x2015e48: 0x00000000
> (gdb) x length
> 0x3d6c20: 0xffffffff
> but not sure about this.
> I tried to identify the changes between ERC32 BSP in RTEMS 4.8.0 (in
> which hello world example works ok) and RTEMS 4.6.6, but I'm not
> succeeding to understand the full startup project.
> I'm aware 4.6.6 is no longer being supported, but any tip on what to
> look for would be really appreciated.
> Thanks in advance,
> Nicolás Horro
> rtems-users mailing list
> rtems-users at rtems.org
Andrei Chichak
Systems Developer
CBF Systems Inc.
4-038 NINT Innovation Centre
11421 Saskatchewan Drive
Edmonton, Alberta
Canada
T6G 2M9
Phone: 780-628-2072
Skype: andrei.chichak
