Gumstix on Qemu
    Thomas Dörfler
    Thomas.Doerfler at embedded-brains.de
    Wed Sep 30 13:45:48 UTC 2009
Joel,
just as a side note: current U-Boot sources also contain a method to
boot a vanilla ELF file. This might be a nice way to get rid of the
"mkimage" problems :-)
There should be a command "bootelf" to do so, if the U-Boot has been
configured that way before compilation.
wkr,
Thomas.
>> Hi,
>> I was curious about running the Gumstix BSP
>> on Qemu and made some progress.
>> http://www.rtems.org/ftp/pub/rtems/people/joel/gumstix/
>> I can't figure out how to get the Flash setup so
>> the U-Boot image of the RTEMS application is
>> in the right place for it to automatically boot.
>> It is booting the U-Boot image in the ftp directory above
>> and I can type at the prompt.  It seems very close to
>> working. :)
> I played around more and can definitely see the
> RTEMS U-Boot image at the Flash address I
> placed it when building the Flash image.
> I think if someone could provide the mkimage
> command they use to run RTEMS apps on a real
> gumstix, this would work
> --joel
>> Any help is appreciated.
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
