LPC2478 patch
Tue Apr 6 06:47:50 UTC 2010
Hello,
thanks for your patch.  The frame buffer driver sources need a proper copyright
and license header.
You changed a lot in the Ethernet driver.  What was the problem with the
previous version?  You removed the conditional code of the
LPC_ETH_CONFIG_USE_TRANSMIT_DMA define.  Why have you done this?  You removed
the LPC_ETH_RX_DATA_OFFSET related code, how did you solve the IP-header
alignment problem?
CU
On 04/05/2010 05:34 PM, Сергей И. Королев wrote:
> patch adds support for the driver lcd framebuffer on lpc2478, support
> SK MLPC2478 board. also attempt to fix the problem with buffer
> overrun/overflow in the driver lpc-ethernet.
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
