RTEMS Message Queue Behaviour
Fri Apr 9 12:23:49 UTC 2010
On 04/09/2010 05:10 AM, Aleix Conchillo Flaqué wrote:
> A while ago I experienced strange problems with queues until I
> configured the memory for them. In 4.6.6 CONFIGURE_MEMORY_OVERHEAD
> defines the number of  kbytes necessary to fit your queue messages and
> CONFIGURE_MESSAGE_BUFFER_MEMORY for newer RTEMS versions. Buffers are
> not taken into account when reserving memory for message queues.
If you don't have enough memory in the workspace,
this should result in an out of memory error on the queue
create.  Memory is not allocated for messages on the
fly.
--joel
> Hope it helps,
> Aleix
> On Fri, Apr 9, 2010 at 11:56, Jamie Bowman
> <jamie.bowman at steepestascent.com>  wrote:
>> All
>> I am experiencing some strange behaviour with RTEMS message queues, although
>> I suspect the problem may more to be with the main configuration of the
>> application.
>> I have a multi-threaded system, with a central logging thread. Information
>> is sent from each thread to the logging thread via a single logging thread
>> message queue. At the moment the logging thread simply uses a printf to
>> output the messages it receives. The behaviour we are seeing though is that
>> the logging thread is in a certain instances reading the messages out of the
>> queue in the wrong order and it also seems that some messages are going
>> missing all together. Monitoring the return of the rtems_message_queue_send
>> does not seem to reveal any issues with RTEMS_SUCCESSFUL returned every
>> time. An example of what I am seeing is as follows:
>> Sent: Message 1
>> Sent: Message 2
>> Sent: Message 3
>> Sent: Message 4
>> Sent: Message 5
>> Sent: Message 6
>> Sent: Message 7
>>              LOGGING THREAD
>> Read: Message 1
>> Read: Message 2
>> Read: Message 4
>> Read: Message 3
>> Read: Message 5
>> Messages 3 and 4 are out of order and 6 and 7 never seem to get through.
>> Does anyone have any ideas as to why this may be happening? I am using RTEMS
>> 4.8.1.
>> Kind regards
>>              Jamie
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
