How to solve bsp_specs problem
Mon Apr 12 06:20:46 UTC 2010
Hi,
you use the wrong BSP path.  Please have a look at
http://www.rtems.com/wiki/index.php/RTEMS_Eclipse_Plug-in#Plug-In_Setup
How did you configure, make and install the PSIM BSP?
The -I include paths are superfluous, if you need them something is completely
wrong with your installation.
Paths may start with C: or c:.
CU
On 04/11/2010 07:20 PM, mc080406855 Rehan Ahmad Khan wrote:
> Hello Everyone,
> I am new to RTEMS world and started with rtems-4.10 and installed
> eclipse and configured it for rtems. Now i just have made Hello World
> project for psim but when i build this project it gives one error of
> bsp_specs: No such file or directory. below i am pasting the whole
> output which i got on console tab of eclipse
> *** Build of configuration RTEMS Executable Configuration for project
> Hello ****
> make all
> Building file: ../src/Hello.c
> Invoking: RTEMS C Compiler
> C:/rtems-mingw/opt/rtems-4.10/bin/powerpc-rtems4.10-gcc
> -BC:/rtems-mingw/opt/rtems-4.10/powerpc-rtems4.10/psim/powerpc-rtems4.10/c/psim/make/lib/
> -specs bsp_specs -qrtems -fno-keep-inline-functions -mcpu=603e -Dppc603e
> -I"C:\rtems-mingw\opt\rtems-4.10\powerpc-rtems4.10\include"
> -I"C:\rtems-mingw\opt\rtems-4.10\powerpc-rtems4.10\psim\powerpc-rtems4.10\psim\lib\include"
> -Os -g -Wall -c -fmessage-length=0 -pipe -v -MMD -MP -MF"src/Hello.d"
> -MT"src/Hello.d" -o"src/Hello.o" "../src/Hello.c"
> Using built-in specs.
> Reading specs from bsp_specs
> powerpc-rtems4.10-gcc.exe: bsp_specs: No such file or directory
> make: *** [src/Hello.o] Error 1
> Definitely it would be very basic question but can anybody help me out
> in this regard
> Thanking in anticipation
> Regards
> Rehan Ahmad
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
