ISR handler.
Nick Thomas nick.thomas at pixsan.com
Wed Apr 14 11:44:48 UTC 2010
Hi,
This is possibly in a FAQ, or a basic error on my part.
I am using rtems 4.7.1 with PowerPC.
I have just noticed that my ISR routines are declared like:
void irr_intr(void);
But, the interrupt handlers are installed using ictrl_set_vector, which
requires an rtems_isr_entry function which is declared as :
typedef rtems_isr ( *rtems_isr_entry )(rtems_vector_number);
So, does that mean that my isr handler should really be:
rtems_isr irr_intr(rtems_vector_number v);
I have seen some odd behavior regarding interrupts on this platform, mainly
occasions where the _ISR_nest_level variable gets stuck at 1. Could this be
because the mismatched args to the function has stomped on the stack and
lost the return address?
Regards
Nick
Nick Thomas
Email: nick.thomas at pixsan.com
