Downloading "powerpc-rtems4.10 gcc" for a few hours on Fedora 12
Ralf Corsepius ralf.corsepius at rtems.org
Thu Apr 29 16:24:15 UTC 2010
On 04/29/2010 05:53 PM, Peter Dufault wrote:
> On Apr 29, 2010, at 11:42 , Ralf Corsepius wrote:
> As I said, I'm not a Linux guy.
I am :-)
>    After a google search I tried this:
> [root at finny12 dufault]# yum  --disableplugin=fastestmirror update
> Loaded plugins: presto, refresh-packagekit
> No plugin match for: fastestmirror
> Setting up Update Process
> No Packages marked for Update
> Unsuccessfully.
This is too little info to be able to help.
The log above only tells that yum doesn't find anything to update.
I.e. yum considers your installation to be "up2date".
What are you trying to do rsp. what do you expect to happen?
> So, in your (humble) opinion what's the most painless way to stay up to date with RTEMS tools?
I recommend using one of the supported linux distros on real HW (I.e.
not using a VM).
>    As I said, I'm using Fedora 12, I'll happily try anything you think is better, and as I said, you're doing all the work.
As Fedora is what OAR and I am using, is what comes with best and most
advanced tools, Fedora is the best supported, best tested one and likely
is the easiest to use.
Ralf
