RTEMS Message Queue Behaviour
Aleix Conchillo Flaqué
aconchillo at ice.csic.es
Fri Apr 9 11:08:53 UTC 2010
I think:
rtems_message_queue_receive(a0_mq, &MESSAGE, &LEN, RTEMS_NO_TIMEOUT, 0);
should be:
rtems_message_queue_receive(a0_mq, &MESSAGE, &LEN, RTEMS_WAIT,
RTEMS_NO_TIMEOUT);
I don't know if that's the problem.
Btw, it's Aleix (pronounced as Alesh) not Alexi ;-)
On Fri, Apr 9, 2010 at 12:35, Jamie Bowman
<jamie.bowman at steepestascent.com> wrote:
> Alexi
> A typical message queue is set up as follows:
> rtems_id a0_mq;
> rtems_message_queue_create( rtems_build_name('Q', 'U', 'E', 'A'), \
> 32,
> sizeof(LOGMSG),
> RTEMS_DEFAULT_ATTRIBUTES,
> &a0_mq);
> We send messages by doing the following:
> rtems_message_queue_send(a0_mq, (void*)&MESSAGE, sizeof(LOGMSG));
> And receive messages by doing the following:
> LOGMSG MESSAGE;
> size_t LEN = sizeof(LOGMSG);
> Kind regards
> Jamie
> Jamie Bowman
> Steepest Ascent Ltd
> Ladywell, 94 Duke Street, Glasgow, G4 0UW, UK
> t: +44 (0) 141 552 8855
> e: jamie at steepestascent.com
> w: www.steepestascent.com
> -----Original Message-----
> From: aconchillo at gmail.com [mailto:aconchillo at gmail.com] On Behalf Of Aleix
> Conchillo Flaqué
> Sent: 09 April 2010 11:25
> To: Jamie.Bowman at steepestascent.com
> Cc: rtems-users at rtems.org
> Subject: Re: RTEMS Message Queue Behaviour
> How (parameters) do you create the message queues?
> Aleix
> On Fri, Apr 9, 2010 at 12:21, Jamie Bowman
>> Alexi
>> Thank you very much for your quick response.
>> We have been setting the CONFIGURE_MESSAGE_BUFFER_MEMORY parameter within
>> our configuration, at least to values we think appear to be appropriate.
> We
>> have the following set:
>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 18
>> #define CONFIGURE_MESSAGE_BUFFER_MEMORY 18*32*sizeof(LOGMSG)
>> //NO x DEPTH x SIZE
>> Our system has around 16 threads running, each of which has been
> configured
>> to have a stack size of 8*RTEMS_MINIMUM_STACK_SIZE which is more than
>> adequate for each task.
>> We configure our tasks as follows to accommodate the number of tasks and
> the
>> larger than default stack sizes:
>> #define CONFIGURE_MAXIMUM_TASKS 18
>> #define CONFIGURE_EXTRA_TASK_STACKS
> (18*(8-1)*RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_MAXIMUM_SEMAPHORES 96
>> Are there any other configuration parameters we should be setting to
>> accommodate our setup?
>> Kind regards
>> Jamie
>> Jamie Bowman
>> Steepest Ascent Ltd
> Aleix
>> Conchillo Flaqué
>> Sent: 09 April 2010 11:10
>> A while ago I experienced strange problems with queues until I
>> configured the memory for them. In 4.6.6 CONFIGURE_MEMORY_OVERHEAD
>> defines the number of kbytes necessary to fit your queue messages and
>> CONFIGURE_MESSAGE_BUFFER_MEMORY for newer RTEMS versions. Buffers are
>> not taken into account when reserving memory for message queues.
>> Hope it helps,
>> Aleix
>> On Fri, Apr 9, 2010 at 11:56, Jamie Bowman
>>> All
>>> I am experiencing some strange behaviour with RTEMS message queues,
>> although
>>> I suspect the problem may more to be with the main configuration of the
>>> application.
>>> I have a multi-threaded system, with a central logging thread.
> Information
>>> is sent from each thread to the logging thread via a single logging
> thread
>>> message queue. At the moment the logging thread simply uses a printf to
>>> output the messages it receives. The behaviour we are seeing though is
>> that
>>> the logging thread is in a certain instances reading the messages out of
>> the
>>> queue in the wrong order and it also seems that some messages are going
>>> missing all together. Monitoring the return of the
>>> does not seem to reveal any issues with RTEMS_SUCCESSFUL returned every
>>> time. An example of what I am seeing is as follows:
>>> Sent: Message 1
>>> Sent: Message 2
>>> Sent: Message 3
>>> Sent: Message 4
>>> Sent: Message 5
>>> Sent: Message 6
>>> Sent: Message 7
>>> LOGGING THREAD
>>> Read: Message 1
>>> Read: Message 2
>>> Read: Message 4
>>> Read: Message 3
>>> Read: Message 5
>>> Messages 3 and 4 are out of order and 6 and 7 never seem to get through.
>>> Does anyone have any ideas as to why this may be happening? I am using
>> RTEMS
>>> 4.8.1.
>>> Kind regards
>>> Jamie
>>> rtems-users mailing list
>>> http://www.rtems.org/mailman/listinfo/rtems-users
