_Thread_Dispatch_disable_level gone negative.
Thu Apr 29 10:17:03 UTC 2010
Hi,
On 04/29/2010 12:00 PM, Nick Thomas wrote:
> But, some new info now: I have just seen the same problem occur, but
> _Thread_Dispatch_disable_level is 0xffffffff , i.e. -1;
> This is having the same effect, that no tasks get to run.
> But, what could possibly cause this RTEMS variable to go negative.
this may happen if you have an invalid _Thread_{Disable/Enable}_dispatch()
sequence, a bug in the exception/interrupt handling or a general data
corruption (stack, heap, global data).  The PowerPC exception code has changed
a lot from 4.7.1 to now.
> I am using RTEMS 4.7.1 on a PowerPC. I know it's an older version of RTEMS,
> but it's too late in the project to change that now.
Why? I know the recent PowerPC port of RTEMS pretty well and it works excellent
for us.
> Any comments/suggestions are appreciated regarding this issue.
Update to 4.9.2 or CVS head.
> Regards
> Nick
> Nick Thomas
> Email: nick.thomas at pixsan.com
> rtems-users mailing list
> rtems-users at rtems.org
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
