UART in RTEMS
João Rasta
freakforever at gmail.com
Wed Aug 11 16:50:18 UTC 2010
Hi,
I'm using a LEON3 architecture with RTEMS. I can successfully open() the
UART device but i'm having transmission errors (erroneous packet data).
Accoording to rtems gaisler drivers doc rtems-gaisler-drivers-1.0.2.pdf i
need to register the driver with apbuart_register(&amba_conf) prior to start
TX/RX as well as to configure the driver with ioctl(), but i'm not sure. I
have checked that the baud rate is correclty set.
Do i need to use such functions to get the UART working properly? Or open()
and cfsetospeed() for baudrate set are enough?
Also, are any other remarks i should be aware for using the UART under RTEMS
without issues?
Best,
JM
URL: <http://lists.rtems.org/pipermail/users/attachments/20100811/5673aec3/attachment.html>
