UART in RTEMS
João Rasta
freakforever at gmail.com
Thu Aug 12 16:57:13 UTC 2010
No problem, any help is allways very much appreciated.
On Thu, Aug 12, 2010 at 5:45 PM, Joris van Rantwijk <jorisvr at sron.nl> wrote:
> On Thursday 12 August 2010 18:24:16 João Rasta wrote:
> > Including leonuart.h results in a compilation error:
> > ../src/comms/packet_lib/leonuart.h:57: warning: type defaults to 'int' in
> > declaration of 'amba_apb_device'
> > ../src/comms/packet_lib/leonuart.h:57: error: expected ';', ',' or ')'
> > before '*' token
> Right, sorry.
> I just looked at the gaisler.com version of RTEMS, and it appears that
> the interface to the AMBA bus has been redesigned. The leonuart driver
> will not work on your version of RTEMS.
> > Calling apbuart_register() also results an error: apbuart_register not
> > found. I have included apbuart.h.
> There seems to be a function called apbuart_register_drv() but I'm not
> sure how it works. It turns out that you are running a version of RTEMS
> that I have no experience with. Sorry for the confusion.
> Regards, Joris.
URL: <http://lists.rtems.org/pipermail/users/attachments/20100812/ac734e67/attachment.html>
