RTEMS Workspsace number of used blocks?
Peter Dufault
dufault at hda.com
Tue Aug 17 14:37:10 UTC 2010
(BSP is phycore_mpc5554 based on mpc55xxevb running 4.10)
I think my workspace must be misconfigured. I had a long-running test crash on me and I got this from the monitor "wkspace" command:
C Program Heap and RTEMS Workspace are separate.
Number of free blocks: 1
Largest free block: 352720
Total bytes free: 352720
Number of used blocks: 99
Largest used block: 131096
Total bytes used: 433824
There is "1 free block" left and it is big, with 99 in use. I assume the number of blocks is fixed at 100, and I should have done something to balance the total free area and the number of blocks.
I see there is a unified work area option. Am I better off enabling CONFIGURE_UNIFIED_WORK_AREAS?
I also see some comments about "unlimited objects" in cpukit/sapi/include/confdefs.h. What does this do?
Is there a recent outline of the configurable options?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
