Mutlicast Failing without Adding route
John Wood jwood at scisol.com
Thu Aug 26 19:46:42 UTC 2010
Hi Till,
I applied the patch and works without adding the route now.
Thanks a lot,
John
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Thursday, August 26, 2010 2:40 PM
To: Till Straumann
Cc: John Wood; rtems-users at rtems.org; Eric Norum
Subject: Re: Mutlicast Failing without Adding route
Eric/Till,
If the patch is OK, please add it to the appropriate branches
and update the wiki
--joel
On 08/26/2010 01:33 PM, Till Straumann wrote:
> This may give some insight:
> https://www.rtems.org/bugzilla/show_bug.cgi?id=1381
> HTH
> -- Till
> On 08/26/2010 12:09 PM, John Wood wrote:
>> Greetings all,
>> I am using rtems 4.9.2 on a custom PCB with 2 Ethernet interfaces.
>>  If I don't add a route my multicast sends fail.  Is this the correct
>> behavior?
>> I am not particularly familiar with multicast.  I have loopback
>> enabled and when I receive the message it has the IP address of my
>> interface as
>> Opposed to the broadcast address which seems incorrect to me but is
>> it possibly correct.
>> I tried setting the interface using the IP_MULTICAST_IF but this does
>> not appear to help.
>> Thanks for any insight,
>> John
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
Joel Sherrill, Ph.D.             Director of Research&  Development
