UART in RTEMS
Wed Aug 11 18:30:56 UTC 2010
On 08/11/2010 12:28 PM, Joris van Rantwijk wrote:
> Hi,
> On Wednesday 11 August 2010 18:50:18 João Rasta wrote:
>> I'm using a LEON3 architecture with RTEMS. I can successfully open() the
>> UART device but i'm having transmission errors (erroneous packet data).
>> Accoording to rtems gaisler drivers doc rtems-gaisler-drivers-1.0.2.pdf i
>> need to register the driver with apbuart_register(&amba_conf) prior to start
>> TX/RX as well as to configure the driver with ioctl(), but i'm not sure. I
>> have checked that the baud rate is correclty set.
> I have only a little experience with the APBUART driver in RTEMS.
> It seemed to work fine, but the interface not so nice.
> To use it, I did something like:
> fd = open("/dev/apbuart1", O_RDWR);
> ioctl(fd, APBUART_SET_BAUDRATE, 38400);
> ioctl(fd, APBUART_START, NULL);
>> Do i need to use such functions to get the UART working properly? Or open()
>> and cfsetospeed() for baudrate set are enough?
> cfsetospeed() has no effect, you need to use the ioctl().
> I'm unhappy that the driver does not use the standard termios interface.
> Also the call to apbuart_register() kills my stdin/stdout console.
> Also the driver works only with APBUART firmware cores that have a FIFO.
> We eventually designed a new APBUART driver, using the termios framework.
> If you like, I can send you our driver and you can give it a try.
We would like to get the improvements back into the main tree.
> Greetings, Joris van Rantwijk.
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
