How to use rtems_bsdnet_loopattach()
    Sebastian Huber
    Tue Dec  7 15:47:41 UTC 2010
If nobody objects I will add the loop back interface initialization to
rtems_bsdnet_initialize_network() and remove the rtems_bsdnet_loopattach()
function.  This will lead to linker errors in applications that use the loop
back interface.  It is easy to fix: simply remove the rtems_bsdnet_ifconfig
item of the loop back interface.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
