RES: YAFFS2 experimental support available
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Fri Dec 3 18:32:32 UTC 2010
Excellent, Sébastien!
Does it support wear leveling already?
Att.
Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Sébastien Bourdeauducq
Enviada em: sexta-feira, 3 de dezembro de 2010 13:48
Para: rtems-users at rtems.org
Assunto: YAFFS2 experimental support available
Hi,
I just got to work my YAFFS2 port (flash filesystem):
https://github.com/lekernel/rtems-yaffs2
A few bits are still missing but it is now in an usable state.
It does not use the bdbuf layer and requires a simple flash driver with the
following:
* read/write operations to read and program the flash (the "program" operation
does not erase, and can only set bits from 1 to 0 in the flash array)
* ioctls to retrieve the block size, the flash partition size and to erase a
block (see milkymist_flash.h in https://github.com/fallen/rtems-milkymist for
definitions - right now it's an ad hoc driver, but might serve as a base for a
generic "MTD" layer for RTEMS)
How to use:
* git clone git://github.com/lekernel/rtems-yaffs2.git
* cd rtems-yaffs2/direct/rtems
* make && make install (with the RTEMS_MAKEFILE_PATH environment variable
set)
* use CONFIGURE_HAS_OWN_FILESYSTEM_TABLE and define the filesystem table
like in this example:
const rtems_filesystem_table_t rtems_filesystem_table[] = {
{ RTEMS_FILESYSTEM_TYPE_IMFS, IMFS_initialize },
{ RTEMS_FILESYSTEM_TYPE_DOSFS, rtems_dosfs_initialize },
{ RTEMS_FILESYSTEM_TYPE_NFS, rtems_nfsfs_initialize },
{ "yaffs", yaffs_initialize },
{ NULL, NULL }
You need to #include <yaffs.h> for the yaffs_initialize definition.
* link your application with -lyaffs2
* mount the flash device as yaffs
For a real-life application using it, see:
http://www.milkymist.org/wiki/index.php?title=Flickernoise_build_instructions
YAFFS2 is plain GPL (no linking exception) - so it will remain separately
distributed and not included in the RTEMS tree.
Good luck,
S.
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
