BSP for AT91SAM9263-EK
Fri Feb 5 20:58:36 UTC 2010
On 02/05/2010 01:00 PM, Johannes Schock wrote:
> Hi RTEMS-Users,
> First let me introduce myself:
> I’m head of development of a small technology company in Germany
> (while being head is easy while being the only one developer).
> I work for several years with Realtime-Systems (ARC/Freescale MQX on
> Coldfire, and Keil RL-ARM on ARM processors), and I’m about to finish
> a 12months project with an AT91SAM9263 running Keil RL-ARM, Nano-X and
> FLTK.
> Now I’d like to create a RTEMS-BSP for the AT91SAM9263EK-Board. (Since
> this will be a holiday project, it’ll last for a while.)
> My first goal is to write a new specific interrupt handle with the
> following features:
> Using the benefits of the integrated AIC of AT91SAM9263 (e.g. 8-level
> priority based nesting).
> Separate IRQ from FIQ while only having the IRQ RTEMS-handled and the
> FIQ running free (à no RTEMS-calls from FIQ, but the possibility of a
> single fast handler)
Wonderful.  Hopefully someone will let you know which is the
best BSP to base it upon.  Look in c/src/lib/libcpu/arm/ and
c/src/lib/libbsp/arm for possible code.
> If someone has any hints or found already solutions for problems I
> will face, please feel free to reply.
> I also have a general question concerning licenses:
> ATMEL has released the AT91lib, with support code for many peripherals
> of the device/board. The code is under the following license:
This license looks OK to me.  If I am correct, it is putting absolutely
no burden on the normal RTEMS user or persons they deliver a system
to.  That is the goal.  If you see something in that license that
is different, correct me.
>  *         ATMEL Microcontroller Software Support
>  * Copyright (c) 2008, Atmel Corporation
>  * All rights reserved.
>  * Redistribution and use in source and binary forms, with or without
>  * modification, are permitted provided that the following conditions
> are met:
>  * - Redistributions of source code must retain the above copyright
> notice,
>  * this list of conditions and the disclaimer below.
>  * Atmel's name may not be used to endorse or promote products derived
> from
>  * this software without specific prior written permission.
>  * DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY
> EXPRESS OR
>  * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
> WARRANTIES OF
>  * MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
> NON-INFRINGEMENT ARE
>  * DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT,
>  * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
> (INCLUDING, BUT NOT
>  * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
> USE, DATA,
>  * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
> THEORY OF
>  * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
>  * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
> SOFTWARE,
>  * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> Is it ok to put unmodified and modified portions of code covered by
> this license and the license itself into a RTEMS-BSP?
> Thanks in advance for any replies.
> Regards,
> Mit freundlichen Grüßen
> Johannes Schock
> **Stiefel GmbH**
> Allmend 7/2
> 75038 Oberderdingen
> Webseite: www.stiefelgmbh.de
> <blocked::http://webseite:%20www.stiefelgmbh.de/>
> Tel.: 00 49 (0) 70 45 / 96 27 - 14
> Fax: 00 49 (0) 70 45 / 96 27 - 20
> E-mail: j.schock at stiefelgmbh.de <mailto:sj.schock at stiefelgmbh.de>
> ___________________________________
> Stiefel GmbH Automationssysteme
> Firmensitz: Allmend 7/2  /  75038 Oberderdingen
> Registergericht: Amtsgericht Mannheim
> HRB 240448  /  USt.-ID-Nr.: DE 143 082 998
> Geschäftsführer: Richard Stiefel
Joel Sherrill, Ph.D.             Director of Research&  Development
