bootpc_call() times out
Till Straumann strauman at slac.stanford.edu
Sun Feb 14 20:25:00 UTC 2010
Chris Johns wrote:
> Till Straumann wrote:
>> Chris.
>> I see that on 2008/05/01 you committed changes (authored by folks at
>> mind.be, it seems)
>> that let bootpc_call() terminate if no server can be contacted for
>> some time.
> Yes that is correct.
>> This is different from pre 4.9 behavior which would keep on trying
>> forever
>> until a server replied.
>> What was the rationale for this (AFAIK undocumented) change ?
> I think networking errors at this protocol level that result in a
> panic should be avoided. At a system it is fine to say reboot on a
> BOOTP error if that is your requirement but to code into the bootp
> protocol seem tough on those that wish to implement a different system
> level design. For example to try a second interface or to hand over to
> a configuration tool that can allow switching to a different
> configuration, ie recommissioning equipment.
> I know this is not documentation but it was discussed on the list. :)
> http://www.rtems.org/pipermail/rtems-users/2008-April/thread.html#3343
> http://www.rtems.org/pipermail/rtems-users/2008-November/004439.html
> I will happily change the doco that is wrong. I was not aware the loop
> for-ever behaviour was documented. Where is it ?
I don't know if it was explicitly documented but I do observe
that existing semantics broke.
> FYI the retry bootp code never worked because of a bug I fixed in
> April 2009.
> It's just that up to 4.9 bootpc_init() would wait for a server
to respond (due to the forever loop in bootpc_call()) which
is no longer the case now.
>> IMO the old 'forever' loop made more sense.
> Can you place the call in a loop ?
IMHO bootpc_init() should then repeatedly call bootpc_call().
- Till
> Chris
