RTEMS on CSB337
Wed Feb 17 13:58:52 UTC 2010
On 02/17/2010 07:40 AM, Teng Chee Wan Philip wrote:
> Hi Marcin,
> Personally, I have not used the CSB337 board.  I suppose the console is re-directed to one of the serial ports, like any other embedded boards.
It is indeed.
> Would you like to explain how you start the hello.exe program?
I don't recall the exact details on the csb337 but it is a
MicroMonitor based board.  I recall that you simply tftp
the elf file and it runs.
> I have taken the liberty to post this reply to the RTEMS users mailing list.  Hopefully, someone can help answer your questions.  You can also subscribe and post to the list directly too.  And if you search the mailing list, you might be able to get additional information.
--joel
> Regards,
> Philip
> -----Original Message-----
> From: Marcin krycho [mailto:marcinus_007 at wp.pl]
> Sent: 17 February 2010 18:13
> To: Teng Chee Wan Philip
> Subject: RTEMS on CSB337
> Hello!
> I saw you were working on RTEMS. I have short question
> regarding "hello world" sample program. It uses printf command. Where
> this message should be send? To one of csb337 serial ports, or somewhere
> else? I managed to compile RTEMS, but I have some problems with starting
> hello.exe program.
> BR, Marcin
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
