RTEMS crash with error 18 (RTEMS_CALLED_FROM_ISR) again.
Nick Thomas
nick.thomas at pixsan.com
Wed Feb 17 16:41:40 UTC 2010
Hi,
I have had this error 18 crash again. When the debugger back trace clearly
shows that the call tree originates from a task.
Looking through the disassembly is looks like the error 18 is called from
rtems_region_get_segment function, from line 69 in regiongetsegment.c .
#0 _CPU_Fatal_error (_error=18)
at
../../../../../../../rtems-4.7.1/c/src/lib/libcpu/powerpc/old-exceptions/cpu
.c:380
#1 0x005f3330 in _Internal_error_Occurred (the_source=INTERNAL_ERROR_CORE,
is_internal=0, the_error=18)
at
../../../../../../rtems-4.7.1/c/src/../../cpukit/score/src/interr.c:61
#2 0x005e6e5c in rtems_region_get_segment (id=838926341, size=8,
option_set=1, timeout=0, segment=0xfa421c)
at
../../../../../../rtems-4.7.1/c/src/../../cpukit/rtems/src/regiongetsegment.
c:69
There is some inlined functions involved here, so it's difficult to follow
the code.
But, the disassembly of rtems_region_get_segment clearly shows that error 18
is in there:
(See 6 lines from bottom of the following disassembly list).
(gdb) disassem 0x5e6da4
Dump of assembler code for function rtems_region_get_segment:
0x005e6da4 <rtems_region_get_segment+0>: stwu r1,-64(r1)
0x005e6da8 <rtems_region_get_segment+4>: mflr r0
0x005e6dac <rtems_region_get_segment+8>: stw r31,60(r1)
0x005e6db0 <rtems_region_get_segment+12>: stw r0,68(r1)
0x005e6db4 <rtems_region_get_segment+16>: mr r31,r1
0x005e6db8 <rtems_region_get_segment+20>: stw r3,24(r31)
0x005e6dbc <rtems_region_get_segment+24>: stw r4,28(r31)
0x005e6dc0 <rtems_region_get_segment+28>: stw r5,32(r31)
0x005e6dc4 <rtems_region_get_segment+32>: stw r6,36(r31)
0x005e6dc8 <rtems_region_get_segment+36>: stw r7,40(r31)
0x005e6dcc <rtems_region_get_segment+40>: lwz r0,40(r31)
0x005e6dd0 <rtems_region_get_segment+44>: cmpwi cr7,r0,0
0x005e6dd4 <rtems_region_get_segment+48>: bne- cr7,0x5e6de4
<rtems_region_get_segment+64>
0x005e6dd8 <rtems_region_get_segment+52>: li r0,9
0x005e6ddc <rtems_region_get_segment+56>: stw r0,52(r31)
0x005e6de0 <rtems_region_get_segment+60>: b 0x5e7180
<rtems_region_get_segment+988>
0x005e6de4 <rtems_region_get_segment+64>: lwz r9,40(r31)
0x005e6de8 <rtems_region_get_segment+68>: li r0,0
0x005e6dec <rtems_region_get_segment+72>: stw r0,0(r9)
0x005e6df0 <rtems_region_get_segment+76>: lwz r0,28(r31)
0x005e6df4 <rtems_region_get_segment+80>: cmpwi cr7,r0,0
0x005e6df8 <rtems_region_get_segment+84>: bne- cr7,0x5e6e08
<rtems_region_get_segment+100>
0x005e6dfc <rtems_region_get_segment+88>: li r9,8
0x005e6e00 <rtems_region_get_segment+92>: stw r9,52(r31)
0x005e6e04 <rtems_region_get_segment+96>: b 0x5e7180
0x005e6e08 <rtems_region_get_segment+100>: lis r9,119
0x005e6e0c <rtems_region_get_segment+104>: lwz r9,3392(r9)
0x005e6e10 <rtems_region_get_segment+108>: li r0,0
0x005e6e14 <rtems_region_get_segment+112>: stw r0,20(r31)
0x005e6e18 <rtems_region_get_segment+116>: lwz r0,20(r31)
0x005e6e1c <rtems_region_get_segment+120>: mfmsr r0
0x005e6e20 <rtems_region_get_segment+124>: andc r9,r0,r9
0x005e6e24 <rtems_region_get_segment+128>: mtmsr r9
0x005e6e28 <rtems_region_get_segment+132>: stw r0,20(r31)
0x005e6e2c <rtems_region_get_segment+136>: lis r9,130
0x005e6e30 <rtems_region_get_segment+140>: lwz r0,-7660(r9)
0x005e6e34 <rtems_region_get_segment+144>: cmpwi cr7,r0,0
0x005e6e38 <rtems_region_get_segment+148>: beq- cr7,0x5e6e5c
<rtems_region_get_segment+184>
0x005e6e3c <rtems_region_get_segment+152>: bl 0x5e71a0
<_System_state_Get>
0x005e6e40 <rtems_region_get_segment+156>: mr r0,r3
0x005e6e44 <rtems_region_get_segment+160>: cmplwi cr7,r0,1
0x005e6e48 <rtems_region_get_segment+164>: ble- cr7,0x5e6e5c
0x005e6e4c <rtems_region_get_segment+168>: li r3,0
0x005e6e50 <rtems_region_get_segment+172>: li r4,0
0x005e6e54 <rtems_region_get_segment+176>: li r5,18
0x005e6e58 <rtems_region_get_segment+180>: bl 0x5f32c0
<_Internal_error_Occurred>
0x005e6e5c <rtems_region_get_segment+184>: lis r9,130
0x005e6e60 <rtems_region_get_segment+188>: lwz r9,-7612(r9)
0x005e6e64 <rtems_region_get_segment+192>: addi r0,r9,16
0x005e6e68 <rtems_region_get_segment+196>: addi r9,r31,20
I'm no expert in assembler, but is this something to do with
_System_state_Get ? (Shown a few lines above).
I can't find _System_state_Get in my source code, but the disassembly looks
like this:
Dump of assembler code for function _System_state_Get:
0x005d8594 <_System_state_Get+0>: stwu r1,-16(r1)
0x005d8598 <_System_state_Get+4>: stw r31,12(r1)
0x005d859c <_System_state_Get+8>: mr r31,r1
0x005d85a0 <_System_state_Get+12>: lis r9,130
0x005d85a4 <_System_state_Get+16>: lwz r0,-7560(r9)
0x005d85a8 <_System_state_Get+20>: mr r3,r0
0x005d85ac <_System_state_Get+24>: lwz r11,0(r1)
0x005d85b0 <_System_state_Get+28>: lwz r31,-4(r11)
0x005d85b4 <_System_state_Get+32>: mr r1,r11
0x005d85b8 <_System_state_Get+36>: blr
End of assembler dump.
Can anyone shed some light onto this problem from the above?
Previously I have looked at the ISR_nest_Level variable, but that is zero
when this crash happens.
So, the question is, why does an error 18 occur when in task context?
Any help greatly appreciated.
Regards
Nick
Nick Thomas
Email: nick.thomas at pixsan.com
