RTEMS crash with error 18 (RTEMS_CALLED_FROM_ISR) again.
Wed Feb 17 21:24:17 UTC 2010
On 02/17/2010 03:08 PM, Nick Thomas wrote:
>> Yes.  That's the hint.  A path out of the ISR code isn't doing exactly
>> the right thing.
>>>> The vectoring code is board dependent in your RTEMS version and this
>>>> was fragile.  It could be a very specific path in your BSPs version
>>>> of this code.
> Looking at _CORE_mutex_Seize in coremutex.h. This is the inlined function
> where the error 18 is generated.
> Note, that 18 is hard coded in there. I was searching for the RTEMS_XXX
> defined constant !
> So, the error will be generated if:
> _Thread_Dispatch_disable_level>  0 AND _wait is TRUE AND _System_state_Get()
>> = SYSTEM_STATE_BEGIN_MULTITASKING.
> Now, _wait is always TRUE, and I assume that _System_state_Get() also
> returns TRUE after the system has been running for a while before the bug
> happens.
> So, it looks like the culprit here is the _Thread_Dispatch_disable_level
> variable.
> I will wait for the crash to happen again, and check it's value.
Hmmm... in 4.7.x, it is possible that the stack checker is
using printf which would be trying to lock a mutex.  It was
changed to printk() some time past that point. Do
you have stack checking on?
> Regards
> Nick
Joel Sherrill, Ph.D.             Director of Research&  Development
