__BSD_VISIBLE
Wolfram Wadepohl Wolfram.Wadepohl at ek-automation.com
Fri Feb 5 11:21:13 UTC 2010
Ok my understanding so far is that there are some features in BSD that are
incompatible with POSIX or X/OPEN. So __BSD_VISIBLE should be undefined
when using POSIX API.
I think you cannot globally enable it or not. It depends on what subsystem
you are using.
Wolfram Wadepohl schrieb:
> I want to use MSG_DONTWAIT socket option. In socket.h it is defined, but
> only when also __BSD_VISIBLE is defined. Where is the right place to
> define __BSD_VISIBLE or is it not suitable to define it at all?
Schöne Grüße aus Reutlingen
Wolfram Wadepohl
Forschung & Entwicklung
E&K AUTOMATION GMBH
Werk Reutlingen
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20100205/ef5a11ed/attachment-0001.bin>
