Howto build networ-demos from CVS head?
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 15 22:27:02 UTC 2010
On 02/14/2010 12:52 PM, Leon Pollak wrote:
> Hello, all.
> The question is in the subject...:-)
> May be there is somewhere some manual?
These use the application Makefiles that are not
autoconf and someday, eventually, will go away. But
currently, after you install RTEMS, you will need to
make sure the networkconfig.h file at the top of the
demos is right for your configuration, then
RTEMS_MAKEFILE_PATH=${prefix}/TARGET/BSP make
If you have problems with the demos themselves, please
post. I am pretty sure I compiled them last week.
> Thanks.
--joel
