mvme5500 vme interrupts
rtwas rtwas at comcast.net
Thu Jan 7 00:49:00 UTC 2010
Till Straumann wrote:
>  Attached is a piece of a driver which uses VME interrupts and DMA via
>  the BSP's VME API. I only attached the file that uses the relevant
>  VME routines...
Thanks for the code Till.
It looks like I should be using:
     BSP_installVME_isr() and
     BSP_enableVME_int_lvl()
  instead of using:
     rtems_interrupt_catch().
Is this correct?
Is there anything else I need to do to enable interrupts?
I looked in "confdefs.h" and did'nt see (or understand) anything
in there associated with "interrupt manager" configuration I should
mess with.
The "README.irq" in "libbsp/powerpc/mvme5500" mentions two
functions:
            BSP_enable_pic_irq()
and    BSP_disable_pic_iqr()
but nothing about initilization/configuration.
Help appreciated.
Robert W.
