rtems_interrupt_is_in_progress() not working.
Nick Thomas nick.thomas at pixsan.com
Sat Jan 9 09:58:38 UTC 2010
Hi, I have the following function, which tries to obtain a semaphore, but
first checking that we are not inside an ISR.
But, it doesn't work.
It crashes in rtems_semaphore_obtain call, and the debugger shows that there
is an RTEMS error 18, which corresponds to doing the wrong thing inside an
ISR ( I think ).
So, why doesn't rtems_interrupt_is_in_progress() detect that the call is
inside an ISR?
--- SNIP ---
Void Lock(void)
	rtems_status_code stat;
	if (rtems_interrupt_is_in_progress() == FALSE)
		stat = rtems_semaphore_obtain(M_The_mutex, RTEMS_WAIT, 0);
		if (stat != RTEMS_SUCCESSFUL)
			printf("Lock: rtems_semaphore_obtain returned %d\n",
stat);
--- END ---
Nick Thomas
Email: nick.thomas at pixsan.com
