rtems_interrupt_is_in_progress() not working.
Sun Jan 10 15:43:46 UTC 2010
On 01/10/2010 07:46 AM, Nick Thomas wrote:
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: 09 January 2010 15:38
>> To: Nick Thomas
>> Cc: rtems-users at rtems.com
>> Subject: Re: rtems_interrupt_is_in_progress() not working.
>> On 01/09/2010 03:58 AM, Nick Thomas wrote:
>>> Hi, I have the following function, which tries to obtain a semaphore,
>>> but first checking that we are not inside an ISR.
>>> But, it doesn't work.
>> Which architecture?
> PowerPC 405.
>> Can you set up a simple test like the one I have attached and try it?
>> The attached test sends a signal from an ISR.  It is pretty small.
>> Then it either works or doesn't and I can look at it. :)
> OK, I ran the test you sent to me, and I got this output:
> *** SIGNAL FROM TST TEST ***
> rtems_signal_catch - handler installed
> Signal sent from ISR has been processed
> *** END OF SIGNAL FROM TSR TEST ***
> Not sure how that helps though as the test doesn't use
> rtems_interrupt_is_in_progress() !
I meant to change the test so instead of sending a signal
from the ISR, you check that rtems_interrupt_is_in_progress()
is tested.  Fix the example so it checks it is false from the task
and true from the ISR.  If it doesn't work, then I can verify the
correctness of the test on another architecture.
I suspect this is because the PowerPC keeps interrupt nest
level in a register (if I remember that correctly) and that
information is not propagated to the API.
So we need a test. :)
> Regards
> Nick
>>> It crashes in rtems_semaphore_obtain call, and the debugger shows
>> that
>>> there is an RTEMS error 18, which corresponds to doing the wrong
>> thing
>>> inside an ISR ( I think ).
>>> So, why doesn't rtems_interrupt_is_in_progress() detect that the call
>>> is inside an ISR?
>>> --- SNIP ---
>>> Void Lock(void)
>>> 	rtems_status_code stat;
>>> 	if (rtems_interrupt_is_in_progress() == FALSE)
>>> 		stat = rtems_semaphore_obtain(M_The_mutex, RTEMS_WAIT, 0);
>>> 		if (stat != RTEMS_SUCCESSFUL)
>>> 			printf("Lock: rtems_semaphore_obtain returned %d\n",
>> stat);
>>> --- END ---
>>> Nick Thomas
>>> Email: nick.thomas at pixsan.com
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
