netdemo on mvme 2600/712
Frunzke, Thorsten
frunzke at four-d.de
Mon Jan 11 09:16:18 UTC 2010
Hello all,
I am new to RTEMS. Currently my goal is to run EPICS 3.14.11 with RTEMS 4.9.2 on a MVME2604 / 712 target. Until now it seems like everything but the network works fine under RTEMS. So I tried to run the netdemo example and see what's wrong here.
There was discussion about the RTEMS netdemo four years ago between Till Straumann and Joel Sherrill, where a solution for a similar board was briefly discussed: a missing IRQ routing table for the target board:
http://www.rtems.com/ml/rtems-users/2005/october/msg00028.html
It seems like this is also my problem. For RTEMS there is no IRQ routing table for the Mvme2604/712 in the motorola powerpc bsp. I tried to use the MVME2600/761 table for my board without success (see below). Has anyone successfully run the netdemo for the MVME2604/712 and can help me with this problem?
Best regards,
Thorsten Frunzke
-------- stdout -------
Welcome to rtems-4.9.2(PowerPC/Generic (classic FPU)/mvme2307) on MVME 2600 with
MVME712
idreg 0 = 0x48011057
OpenPIC found at C1000000.
pci : Configuring interrupt routing for 'MVME 2600 with MVME712'
pci : No bridge from bus 0 towards root found
pci : Unable to match device 0:0x0B:1 with an int routing table entry
pci : Device 0:0x0E:0 supplied a bogus interrupt_pin 1
Cleared PCI errors: pci_stat was 0x2280
OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0xC1000000
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
OpenPIC timer frequency is 8334002 Hz
Please add code for PCI/ISA bridge init to libbsp/powerpc/shared/irq/irq_init.c
If your card works correctly please add a test and set known_cpi_isa_bridge to t
rue
currentBoard = 15
Universe II PCI-VME bridge detected at 0xC1041000, IRQ 11
Universe Master Ports:
Port VME-Addr Size PCI-Adrs Mode:
0: 0x20000000 0x0E000000 0x10000000 A32, D64 [MBLT], Dat, Sup
1: 0x00000000 0x00FF0000 0x1F000000 A24, D64 [MBLT], Dat, Sup
2: 0x00000000 0x00010000 0x1FFF0000 A16, D64, Dat, Sup
Universe Slave Ports:
0: 0xC0000000 0x03FC0000 0x80000000 A32, Pgm, Dat, Sup, Usr, PWEN, PREN
Registering /dev/console as minor 0 (==/dev/ttyS0)
Initialize network
dec21140 : found device 'dc1', bus 0x00, dev 0x0E, func 0x00
dec2114x : unit 1 base address C1042100.
dec2114x : driver attached
dec2114x : driver tasks created
dec2114x : 00:01:AF:03:8D:27 name 'dc1', io 11100, mem C1042100, int 10
dec2114x: Installing IRQ 10
taNne'ttw osrekt idneiftaiuallti zreodu
e: Network is unreachable
Thorsten Frunzke 4D Engineering GmbH
- Büro Bayreuth -
Tel.: +49 (0) 921/787773-21 Bindlacher Straße 1
Fax.: +49 (0) 921/787773-18 D-95448 Bayreuth
mailto:frunzke at four-d.de http://www.four-d.de
