Problem installing tools with Yum on RHEL 5.2
Phillip Sorensen pas37 at cornell.edu
Wed Jan 13 15:32:37 UTC 2010
Robert S. Grimes wrote:
> Hi,
> Finally bit the bullet, got a RedHat system, and am trying to install
> the tools using Yum, which is new to me.  Here is the results:
> rsg at ws:~/tmp $ ls
> rtems-4.9-release-0.21-1.el5.noarch.rpm
> rtems-4.9-yum-conf-0.21-1.el5.noarch.rpm
> rsg at ws:~/tmp $ rpm -ivh rtems-4.9-yum-conf-0.21-1.el5.noarch.rpm
> warning: rtems-4.9-yum-conf-0.21-1.el5.noarch.rpm: Header V4 DSA
> signature: NOKEY, key ID 69ce4a83
> error: Failed dependencies:
>         rtems-4.9-release = 0.21-1.el5 is needed by
> Looks like I'm missing something, though it seems I'm following the
> wiki instructions...
It looks like you need to install rtems-4.9-release first or at  the
same time. Try
rpm -ivh rtems-4.9-release-0.21-1.el5.noarch.rpm
Phil Sorensen
