Can not compile CVS
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Tue Jan 26 16:35:12 UTC 2010
Leon,
meanwhile the "make/custom" directory has been abandoned and the
relevant files have moved to c/src/lib/libbsp/<arch>/bsp/make/custom .
I do not know which other changes have occured concerning the structure.
wkr,
Thomas.
Leon Pollak wrote:
> Hello, all.
> I try to switch to the CVS version and fail...:-(
> I downloaded and installed all tools.
> I took my 4.9.3 BSP and copied it into the new tree, copied also the cfg file
> into "make/custom" directory, run bootstrap, configure, make and failed:
> bash-4.0$ make RTEMS_BSP="uMon_8260"
> ..........make tools testsuits passed OK........
> Making all in powerpc-rtems/c
> gmake[1]: Entering directory `/opt/rtems-4.10/build.dbg/powerpc-rtems/c'
> Making all in .
> gmake[2]: Entering directory `/opt/rtems-4.10/build.dbg/powerpc-rtems/c'
> gmake[2]: *** No rule to make target `uMon_8260', needed by `all-local'.
> Stop.
> gmake[2]: Leaving directory `/opt/rtems-4.10/build.dbg/powerpc-rtems/c'
> gmake[1]: *** [all-recursive] Error 1
> gmake[1]: Leaving directory `/opt/rtems-4.10/build.dbg/powerpc-rtems/c'
> make: *** [all-recursive] Error 1
> Please, what do I miss?
embedded brains GmbH
Thomas Doerfler        Obere Lagerstrasse 30
D-82178 Puchheim       Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
PGP:   Public key available on request.
