Want to use the powerpc e200z6 SPE APU
Mike Arthur
arth2219 at gmail.com
Wed Jan 27 18:40:58 UTC 2010
Peter,
Have you had any more success with hacking SPE support?
Mike
On Sun, Oct 11, 2009 at 11:31 AM, Peter Dufault <dufault at hda.com> wrote:
> On Oct 11, 2009, at 9:12 , Peter Dufault wrote:
> though the disassembler doesn't handle the instructions properly:
> After this I promise I won't follow-up on myself, especially on weekends
> when everyone else is taking time off.
> Obviously I'm overly busy right now.
> You will find yourself in a twisty maze of options when working with the
> SPU, to disassemble the SPE op-codes use -M e500:
> [dufault at finny rtems]$ powerpc-rtems4.10-objdump --disassemble -M e500
> foo.o
> foo.o: file format elf32-powerpc
> Disassembly of section .text:
> 00000000 <foo>:
> 0: 94 21 ff e8 stwu r1,-24(r1)
> 4: 3c 00 3f 00 lis r0,16128
> 8: 90 01 00 10 stw r0,16(r1)
> c: 3c 00 be 00 lis r0,-16896
> 10: 90 01 00 14 stw r0,20(r1)
> 14: 10 01 13 01 evldd r0,16(r1)
> 18: 10 00 02 97 evfsctsf r0,r0
> 1c: 10 01 0b 21 evstdd r0,8(r1)
> 20: 38 21 00 18 addi r1,r1,24
> 24: 4e 80 00 20 blr
> rtems-users mailing list
> rtems-users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20100127/501e13fc/attachment.html>
