RES: Trying to get Idle Task ID
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Thu Jan 28 12:35:41 UTC 2010
Hi Joel,
>> Why do you need to get the ID this way?  The code you based it
>> upon just dereferenced the TCB pointer.
I don't needed to get the ID "this way", I just needed to get the ID ;-)
>> The ID is constant so you could just hard code it. :)
I had tried that, but the constant I've used was wrong, and so my test
didn't work. Now I checked and corrected it.
Thanks Joel (and Wendell!) and congratulations for the 21st anniversary of
your "son"!
Fabrício.
