How do I access my VME hardware from MVME3100?
Till Straumann strauman at slac.stanford.edu
Fri Jan 29 01:26:51 UTC 2010
rtwas wrote:
> Dimitrios Tsifakis wrote:
>>  Hello everyone,
>>  I am a new RTEMS user. I have just managed to compile 4.9.3 for an
>>  MVME3100 and run the hello_world_c program. The second step I had in
>>  mind was to access the VME cards that are also installed in that
>>  crate, but I cannot find any documentation that describes how to
>>  achieve that.
>>  Any help and pointing to the right direction would be greatly
>>  appreciated.
>>  Regards Dimitris
> Hello,
> My understanding is that the mvme ppc bsp's use the motorola setup
> defaults for each of the address space types (32bit (extended), 24bit
> (standard), 16 (short io)).
That's not correct. The BSP programs its own mappings which you
can display with
BSP_VMEOutboundPortsShow(stdout)
you can change this using BSP_VMEOutboundPortCfg(),
c.f. the header file in <src>/c/src/lib/libbsp/shared/vmeUniverse/VME.h
> The BSP_vme2local_adrs() function (according to Till) just does a
> verification of an
> existing mapping.
> This function doesn't do any mapping but it checks if the given local
> address is mapped on the VME bus ('visible to other VME masters')
> using already existing mappings and translates it into a VME address.
> " -Till Strauman
> You need to use a "BSP" function, here's a 24bit (Standard) address space
> example:
>      unsigned long    local_address;
>   volatile uint32_t * vme32p;
>  return = BSP_vme2local_adrs(VME_AM_STD_SUP_DATA, 0x00000000,
> &local_address); // map the space
>  if(return <0)
>     printf("BSP_vme2local_adrs(): failed \n");
>  else
>     // to acess address 0x1000
>    *(vme32p + 0x1000/4) = 0xdeadbeef; // for a 32 bit word write
> // the "/4" thing is there because the address space is in *bytes* but
> the pointer
> // is 4 times that size.
> The "am" codes can be found:
> "/opt/rtems-4.9/powerpc-rtems4.9/mvme5500/lib/include/bs/vme_am_defs.h"
>         (in the case of an mvme5500 on a Linux system install)
>          -or-
>          "./c/src/lib/libbsp/shared/vmeUniverse/vme_am_defs.h"
> The relevant BSP functions can be found:
>             "c/src/lib/libbsp/powerpc/shared/vme/vme_universe.c"
> If your write/read *order* is important you'd probably want to do an
> *inline* "eieio" instruction
> to force "in order execution". There was talk in one of the past
> emails about using some io functions
> to do this but I've not located them yet.
> I asked this question not long ago. You should be able to find it in
> the email archives.
> Robert W.
> rtems-users mailing list
> rtems-users at rtems.org
