rtems_interrupt_is_in_progress() not working.
Mon Jan 11 08:10:48 UTC 2010
Nick Thomas wrote:
> But, I suspect that my problem is caused by rtems_interrupt_is_in_progress()
> being called from within a genuine hardware interrupt - not a timer
> interrupt.
> Does that make a difference?
It should not make a difference.  Which RTEMS version and BSP do you use?  How
do you install the interrupt handler?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
