Sending or receiving multicast packets
Till Straumann
strauman at slac.stanford.edu
Mon Jan 25 14:26:31 UTC 2010
Joel Sherrill wrote:
> On 01/25/2010 05:56 AM, Diego Sanz wrote:
>> Hi to everyone!!
>> In this days I have done several questions in the forum about sending
>> and receiving multicast packets with rtems.
>> I think that now I have a more specific question.
>> ¿do I have to modify only the driver in the path
>> /home/rtems/rtems-work/rtems/c/src/lib/libbsp/m68k/mcf5235/network,
>> or I have to modify somthing inside the source of RTEMS too?
>> If someone knows something, and knows which structure and in wich
>> file I have to do some modifications, I will be very grateful!
> Multicast works fine with RTEMS. The driver does have to support a
> couple of
> multicast IOCTL's. See libbsp/powerpc/gen5200/network/network.c for
> an example
> of a driver that has the boiler plate to handle the IOCTL but the NIC
> requires no
> actions to enable it.
Don't forget to add IFF_MULTICAST to the interfaces' if_flags....
-- Till
> There is a standard multicast demo program from the net modified slightly
> to run on RTEMS in the network-demos/multicast.
> So this is no big deal but does require NIC multicast support.
> --joel
>> Lot of thanks!!
>> Diego
> rtems-users mailing list
> rtems-users at rtems.org
