RES: Trying to get Idle Task ID
Wendell Pereira da Silva wendell.silva at compsisnet.com.br
Wed Jan 27 20:29:15 UTC 2010
Hi Fabricio,
I got something even strange.
I tried here the following code:
rtems_id id;
rtems_status_code lenStatus =
	rtems_task_ident(
	rtems_build_name('I','D','L','E'),
	RTEMS_SEARCH_ALL_NODES, &id);
printk("%d, %d\n", lenStatus, id);
I got RTEMS_SUCCESSUL and id == 0 (zero).
But when id == 0, it is supposed to be RTEMS_SELF!
Could anyone else help us?
BSP: sparc/erc32
RTEMS_VERSION=4.8.1
Att.
Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org] Em nome de Fabrício de Novaes Kucinskis
Enviada em: quarta-feira, 27 de janeiro de 2010 16:33
Para: 'RTEMS Users'
Assunto: Trying to get Idle Task ID
Hi all,
I'm trying to get the total amount of time used by any task (in
microseconds) as an unsigned long value that I can insert in a telemetry
packet.
For this purpose, my code is based on "rtems_cpu_usage_report_with_plugin",
and, AFAICT, it works correctly.
The function receives the task ID, loops through the Objects Information
Table, identifies the correct task and gets the amount of time.
The problem is that I cannot get the Idle task ID. I tried
"rtems_task_ident(rtems_build_name('I', 'D', 'L', 'E'))", but I receive an
"RTEMS_INVALID_NAME" error. I tried with "idle" and "Idle", with no results.
I also tried a constant from the CPU Usage chapter in the RTEMS C Users
Manual, "0x0401001", and got the same error.
>From an old (2006) post, I discovered that the Idle task name is a string,
so I tried to cast that string into a rtems_name variable. No way!
So, how can I get the Idle task name or ID? (I'm using RTEMS 4.8.1)
Thanks in advance,
Fabrício de Novaes Kucinskis - DEA / INPE
Onboard Data Handling Group - SUBORD
Aerospace Electronics Division
Brazilian National Institute for Space Research
rtems-users mailing list
rtems-users at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-users
